Vand routere mobile mi-fi . Routerele sunt noi . Am trei bucati.
Pachetul contine : 1 x router mifi
1 x acumulator
1 x cutie originala
1 x cablu pentru incarcare (usb-mini usb)
1 x manual de utilizare
Product Name
3G Wireless Router (3G router)
Description
-The device upstream connect 3G wireless broadband signal or wired broadband signal, downstream transport WIFI wireless signal, multi-devices with WIFI function can share broadband network and inter-visite among devices
-The device can supply broadband network with stable and reliable signal in the open air, on the high-speed running train, at office meeting and hotels, help you surf the internet and online office at any time and anywhere
Access Mode
-3G Wireless access (WCDMA/EVDO/TD-WCDMA)
- WIFI wireless access
- WAN port wired access
WIFI Hotspot
- Support 802.11 b/g/n
- WIFI connect max broadband 150Mbps
- Support over 30 wifi clients port connection
Router Function
- Support NAT/NATP function
- Support DHCP Server/Client
- Support virtual server and DMZ function
- Support VPN pass-through (IPSec/PPTP) function
External Port
- One share Ethernet port with 10/100Mbps LAN/WAN
- One USB 3G network and port
- One mini USB charger port
Parameter
108mm*65mm*25mm
Lista modemurilor 3g suportate
Pretul este fix. Predarea este personala in Bucuresti, NU trimit in provincie.
Cutiile au fost desfacute doar pentru a proba routerele cu un stick digi (zte mf 110).Ajut la configurarea routerelor.
PRET fix 150ron.
Vand routere mobile mifi
- dan_paul
- Site Admin
