Pret:550 euro
Telefon:0723000222
CEL MAI USOR LAPTOP DIN LUME NU NETBOOK!!!
ARATA CA NOU , FOLOSIT 4 LUNI DE ZILE, FARA ZGARIETURI SAU LOVITURI
HDD DE 320GB/7200RPM
AM LA EL 2 INCARCATOARE UNUL PENTRU BIROU SI UNUL PENTRU ACASA + O BATERIE NOU-NOUTA, CEA DE PE EL TINE DOAR 3,5 ORE
PRODUSUL DIN IMAGINE SE AFLA PE STOC ESTE FOLOSIT DOAR 2-3 LUNI, ESTE CA NOU FARA ZGARIETURI SAU LOVITURI.
CD DE VISTA SI XP PRO
LIVRARE NUMAI IN BUCURESTI.
-PENTRU MAI MULTE INTREBARI VA ROG SA INTREBATI PE FORUM
-NUMAI IN BUCURESTI SAU IN ALTE ORASE CU PLATA AVANS PRIN TRANSFER BANCAR
-ACCEPT ORICE VERIFICARE
Technology type : Intel® Centrino® 2 with vPro technology featuring Intel® Core 2 Duo Processor SU9400, Intel® GS45 Express chipset and Intel® WiFi Link 5100
clock speed : 1.4 GHz
front side bus : 800 MHz
2nd level cache : 3 MB
Operating System / Platform Genuine Windows Vista® Business 32-bit Edition (pre-installed, Toshiba-HDD recovery) + Downgrade to Genuine Windows® XP Professional Edition (Toshiba-Recovery DVD)
System memory standard : 3,072 (1,024 onboard + 2,048) MB
maximum expandability : 5,120 MB
technology : DDR2 RAM (800 MHz)
Hard disk capacity : 320 GB
certification : S.M.A.R.T.
drive rotation : 7,200 rpm
capacity : 320 GB
DVD Super Multi drive compatibility : CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
maximum speed : Read: 24x CD-ROM, 8x DVD-ROM/ Write: 24x CD-R, 4x CD-RW, 10x HS CD-RW, 10x US CD-RW, 8x DVD-R, 4x DVD-RW, 8x DVD+R, 4x DVD+RW, 3x DVD-RAM
type : Ultra-slim DVD Super Multi drive
Display size : 30.7cm (12.1")
type : WXGA Transflective TFT High Brightness display with LED backlight technology
internal resolution : 1,280 x 800
Graphics adaptor type : Mobile Intel® GMA 4500MHD
memory : up to 1,332 MB total available graphics memory with 3 GB system memory
memory type : shared
Internal video modes The following internal video modes are supported:
Max External Video Modes Max Resolution : 1,920 x 1,200
Max Refresh Rate : 100 Hz
Non-interlaced resolution with max refresh rate : 1,280 x 1,024
Interfaces 1 × DC-in
1 × external monitor
1 × RJ-45
1 × SD Card slot
1 × external microphone
1 × built-in microphone
1 × headphone (stereo)
2 × USB 2.0
1 × integrated VGA Web Camera
1 × eSATA/USB 2.0 Sleep-and-Charge
Expansion 1 × memory slot
1 × ExpressCard slot
1 × connects to Slim Port Replicator III (optional)
Wireless communication Wireless Technology : Bluetooth®
Compliancy : Wi-Fi™
Network Support : 802.11a/g/Draft-N
Manufacturer : Intel®
Wireless Technology : Wireless LAN (802.11a/g/Draft-N)
Compliancy : 3G
Network Support : HSPA/UMTS at 2100 MHz and GSM/GPRS/EDGE quad bands at 850/900/1800/1900 MHz
Manufacturer : Ericsson
Wireless Technology : Mobile Broadband WWAN/3G (HSDPA 7.2Mbps / HSUPA 2Mbps)
Wired communication topology : Gigabit Ethernet LAN
speed : 10BASE-T/100BASE-TX/1000BASE-T
Sound system supported audio format : 24-bit stereo
speakers : built-in speaker
Keyboard keys : 86
Windows keys : Yes
special features : spill-resistant keyboard
Pointing device type : Touch Pad
Battery technology : lithium-ion
maximum life : up to 8h25min (Mobile Mark™ 2007)
AC adaptor input voltage : autosensing AC adapter (100/240 V) for worldwide usage
output voltage : 15 V
output current : 3 A
Physical dimensions W x D x H : 283 x 215.8 x 19.5 (front) / 25.5 (rear) mm
weight : starting at 1.114 kg
Warranty 3-year international warranty. Upgrade your standard warranty with Toshiba warranty extension and uplift packs.
Bundled hardware
Portege R600-11B, 12.1TFT, 1.40GHZ , 3072MB, 320GB/7200RPM
- sonyscorpion
- Tipul: IX35
- Capacitatea cilindrică: 2000
- Combustibil: diesel
- Anul fabricaţiei: 2010
